Hi guys,
I took the top off last night and inspected the belt and tray. After giving it a bit of a clean and a tap here and there, managed to get the tray to open and close. The belt is OK, though is showing signs of perishing. Interestingly, a spare band has been left packaged inside the box, so may replace the old one when I feel a little more confident.
Thanks for you help and feedback, most appreciated!
I'll start tackling my next two issues - being noisy turntable motor and no output from the amp. Will be back in touch if I can't resolve, you guys are great!
Cheers,
Shef.
