Beogram CD 5500 right channel no sound
Hi B&O Fans,
a new small project on my table.
A Beogram CD 5500. After replacing the famous capacitor the CD runs now.
But unfortunately only on the left channel.
Cause i don´t have an oscilloscope - is there anything else, i should take a deeper look at?
I checked the solderings, but nothing obvious.
Best regards
69er
I would check the relay first. Perhaps the right channel isn't making adequate contact.
Hi quatttro,
where is the relay in a Beogram cd?
best regards
69er
Check the filter capacitors and their respective resistors for the opamps in the analogue output stages.
