Hello,
Today i picked up a good working (i see) Beogram CD 5500 from Germany.
When i come home i open the cover and clean the laser with a tip and alcohol 96% (do this more than 20 years with no problem)
Also i remove dust from the pcb with contact spray.
I set the player to my set and now it does not play anymore :(
the cd load and the cd spin and i check the red laser light but the player goes back in standby.
any suggestions?
I hear the motor a little bit growl.
But i drive more than a hour. maybe wait that everything is on correct temp?
