Beogram CD-50 - Lower Disc Holder 9132
Yes I saw in the comments to the suggestion that the motor requires cleaning and or lubrication. However the two non-working players that I have both had broken belts, so I am reluctant to believe that 2 players both developed in addition a problem with the motor. Also one player I am repairing for a friend who told me that discs were playing fine before the cd tray stopped ejecting, So unless this two issues are a symptom of one another I am reluctant to start stripping the motor down especially since it appears not not to be a simple job.
Fully understandable. I will also look into other options before trying that. But always a good idea to look into what Others have found in older threads. I will update if I find something relevant.
Seems to be some succes rate with spindle motor cleaning, but it also sounds like a hard job to disassemble it
One thing I note is in one of the later posts the adjustment of the brass nut on the cam wheel is again mentioned for being responsible in how easy a disc will rotate
So so progress of sorts.
On player #1 - I still cannot get the disc to clamp properly but I think it is because I am missing the springs which keep the raiser level when it rises.
On player #2 - I played with the brass knob, too tight and discs won't rise, but I loosened it and the disc is clamped and I can see it spinning. I gave the spindle motor a nudge and it starts to spin - but clearly it has a problem. It is quite noisy. But the TOC seems to be read as I see the correct number of tracks on the display and I can move through the track - but they don't play. So I believe the issue on this player is the motor.
Even though my CD50 is playing now it still can have time when it spit the disc out at first try. Also on every disc I tried it will start playing 1-2 minuttes into the first track and can sometimes have issues with tracks where it will not play and the counter is just showing the track number. It allways read the TOC though when the disc stays in.
Player #1 is now playing the discs. With a light source I shone into the side of the player I could see that when the disc was raised there was still a 1-2mm gap between the disc and the grabber. So I further tightened the brass knob and although I was sure the cam could not be any lower it made a difference. the disc now spins and will play the disc seemingly without any issues - although I have not listened to any music only observed.
So a note of warning - the sound heard in the video posted above in my case was not related to the spindle motor issue which the comments suggested was the issue.
Player #2 is still not playing discs but I suspect the issue here is the motor which I probably have nothing to lose in attempting the service.
For the temperamental issues of the player have you tried cleaning the laser lens - and are the cams on the laser housing all complete and lubricated?
So a note of warning – the sound heard in the video posted above in my case was not related to the spindle motor issue which the comments suggested was the issue.
Ok good to know. Will experiment a lttle more with the brass know before going into motor issues.
On your player #1 have you noticed if the CD start the counter at 0.00 or if it is a minute or more into the first track?
  It starts at 00:00 - the start of the track according to the display. I noticed that on my player #2 i was displaying 00:00 too but would not begin playing the disc. On player #1 I have made the necessary adjustments to the draw to make it close nicely - I couldn't figure out why the eject wasn't working (by pushing the draw fascia) - only manually engaging the micro-switch worked. The fascia of the tray fixes and snaps down on to the hinge (see arrow 1), mine was not fully engaged so when the draw closed the back of the fascia was not making contact with the lever arm for the eject - that took some figuring out. I also managed to find a screw to secure the arm of the tray which had become detached (see arrow 2). Originally it looks like a tiny rivet was used, I found a screw which does the job.
The final job is to add some springs that keep the lower disc raiser level - that might be the most challenging job yet.
I managed to get player #2 working, or at least playing discs today.
I first removed the laser carriage (via the 4 screws) and wound the white plastic grub screw that comes out of the carriage motor. It took a few turns but eventually the carriage moved about 10mm. I then powered up and the carriage returns to the stop position - which I think proves that the carriage motor is ok.
I then tried to play a disc, I only had 2 of the laser mechanism screws in loose to keep the mechanism in place. Seemed to play ok - I then put all 4 screws in tight and the disc would not play and the disc was lightly knocking or rubbing against something. I noticed that if I loosen the front two screws and lift the mechanism with my fingers by a mm or two the playback works fine and the rubbing stops.
So I think the spindle needs to be adjusted - lifted up so that the disc is spinning a little higher than at present. Perhaps in your case if you have temperamental playback it could be related to this same issue - just try lifting the mechanism once the cd is loaded to see if it makes a difference!
Great hint. I will certanly try that the next time I work on it.
One thing I wonder though is if it makes a difference to adjust the spindle height vs. Adjusting the lifting mechanism
I have now tried to lift the Mechanism slightly, and saw an improvement on some CD's which now starts at 0.00 or 0.03. Tried to adjust the brass know more loosly and that also give this result. However there are still some of the CD's I am using for testing that starts between 1-2 minutes into track 1, so does not solve every case for me. If I remeber correctly I saw something about CD thickness in one of the older threads. Will have to go back and read up on that
