I was able to complete the repairs today. In addition to the above issues, I noticed the entire disc tray was off its track, dislodged from the track guide (9147 - Guide, lefthand - front).
I proceeded as planned, removing the main cam wheel and disc arm to reseat the entire mechanism.
After reassembly and testing, everything else seems fine.
Some more notes for anyone else looking to refurbish a unit:
- The original belt will be so goopy and melted at this point that removing it cleanly from either the Pulley (9128) or Load Motor (91M301) is only possible by *removing* both.
I had not taken out any of the PCBs so I did not want to start that just to get to the Load Motor. I simply scraped out as much of the melted belt as possible (using angled needle point tweezers). Then I simply put on the generic replacement belt. Im not sure what impact the new rubber rubbing against the old goop will have long term.
- I used a generic ~42mm x 0.9mm belt from Amazon as a replacement for the disc drive. I tested at least a dozen open-close-play cycles and it seems to work. Though its definitely not as smooth moving or sounding as I imagine it could be. However, looking at how this entire mechanism works, I see no reason this belt wont be 'good enough' for my use. Its also possible the original belt goop I left on the motor pulley is causing this.
- If you have to remove Part 9151 (Back left CD assembly holder) you will not be able to put it back in without removing the Arm (9219).
I closed the unit back up with two lazy mistakes - I was not able to get the E-ring (retention ring) back onto the Pulley (9128). Given the overall overbuilt design, Im hoping it will be fine without it. I also didnt reattach the arm mentioned above (9151).
Overall, these repairs took quite a while as I was totally unfamiliar with vintage stereos before this. Id say about 6 hours total including research.
Now this CD50 will join the rest of a repaired Beosystem 5500. Thank you for the assistance!
