I finally got round to working on the BG again. Checked processor leads, checked connectors on the can.
I replaced C28 in the can, I had already removed it last time for testing its value. This changed everything, I think for the better! BG starts with the red dot and responds to buttons, drives the arm and platter looking stable with correct display. This makes me think the PSU and on/off from uP are OK. However, not all is well yet...
New symptoms
When play is pressed the arm drives in but never stops. It goes all the way across, the BG does not switch to 45, the motor keeps running when the arm has reached its ultimate position. Pushing stop makes it return to base, the motor does stop there and BG goes back in standby.
The BG can manually be switched to 45, this will make the platter spin faster.
Records on the platter are not detected, the arm behaves the same with or without record.
The arm responds to << >> and play. The arm can be moved onto the record with << and >> and will then sink down on the record when pressing play. The arm will move tangentially with the grooves for half a minute, after that it stops as if it has reached the end of a record and goes back to standby position.
What changed?
I'm still having the BG turned on to test stability, but maybe the first issue is now solved. Maybe either C28 was bad (was rather high voltage spec, about 50V. I read bigger caps sometimes get 'lazy' doing low voltage 5V work) or maybe a connection on C28 was bad and now the processor is stable again.
What now?
For the problem that remains my differential diagnosis is as follows, in order of likelihood:
- P2 connector was changed by me, maybe made a mistake. Counting of the worms rotations happens through there so quite likely to cause the running arm.
- maybe bad adjustments make the BG not read the ribs on the platter.
The detector and pickup arm were adjusted by me somewhere during the
repair process because they seemed misadjusted somehow. Probably just
had everything wrong because both are now too low. If the BG proves
stable I'll do adjustments, will be necessary anyway if I get everything working again.
- If C28 was bad, maybe some of the other caps replaced by previous owner are bad. Might replace them all.
Questions:
Do these symptoms point to another specific place for the problem? Am I on the right track? Any other/better suggestions on where to look?
Of course I could still be seeing one of those intermittent 'it seems to be working again' moments now. Keeping thumbs crossed...
