Hello all,
I have had a BG8002 as part of my 8000 system for about 4 years now I think. Unfortunately it started acting up some time ago: not starting, showing 33 as soon as I plugged it in, just erratic behaviour pointing to the common problems of bad caps and or connections.
Some caps were already replaced by the former (very knowledgable) owner. I replaced the rest of the old caps. I resoldered and cleaned the connectors on main and processor PCB and every other bad looking joint. Worked fine for maybe a day and then went wonky again!
Resoldered lots of connectors again, replaced 5V regulator as it gave 4,8V instead of 5V. worked for a day and went whacko again!
Replaced the processor IC socket. Worked for a few days and then the bad stuff started over again.
I suspected the 'bare wire into socket' connectors of the processor can and keyboard-to-main pcb connectors. Replaced them with more sturdy new connectors. Again the BG worked fine for a few tries and... then the erratic stuff started over.
I'm going slightly mad now. What shall I do? Inspection under magnifying glass did not show any broken traces but could have missed something.
My differential diagnosis:
- bad soldering or broken trace or shorted solderings somewhere that I have missed
- bad 4n7 ceramic on the processor board
- bad microprocessor IC
My questions:
- How can I check if the processor is fried? If this is the case any soldering will be for nothing.
- What should be my next step? I've opened the BG up one too many time and can't really see clearly anymore.
Any suggestions or moral support would be greatly appreciated!
