My BG8002 has died. When plugged in there is no response, no standby dot.
F1 was blown, D20 short circuited and blackened the PCB. I replaced both and got the +5v back on P6-1 .However still no response, no standby dot. Due to the damage to D20 I suspected the reset circuit. P6-3 measures +5V, which I think means the reset is active so the turntable wont start up. I checked TR17 on my HFE meter, it had HFE 0 so I replaced it with a new BC557B. However still no response. The three resistors R74,75,76 measure within spec.
First question before I dig deeper: am I correct that the reset circuit is now active and should have 0V on P6-3?
