So I shipped a beogram turn table to another state. When the turntable arrived the main platter not the one the record sits on had popped up. Now the turntable with not spin, If anyone has any ideas on what might have happened or how to fix this I would appreciate it. Thank You.
Beogram 8000 Turn Table won't spin
There are a number of things from something electronic (like a connector coming loose during shipping) to mechanical (like the tachodisc under the platter failing). Was the Beogram original and working before you shipped it? If the tachodisc is original did you examine the state it was in? The original Beogram 8000 tachodisc was a plastic laminated disc that deteriorates over time. See this post. It could also be a problem with a board connector coming loose but accessing those to check are not something for a novice to attempt as it is easy to damage something if you don't know what you are doing.
sonavor
The turntable was in perfect working order before shipment, I did not examine any parts before shipment and the person I bought it from did not say anything about haveing it worked on at any point in time. Is the tachodisc something that a novice could replace. I have asked the buyer if the unit is humming thinking maybe the capacitors went bad during shipment. Thank you for your reply
I did lock the 3 mechanism before shipment, I did not take the plater off the turntable before shipment. What kind of damage could this have caused during shipment.
A person would have to have decent mechanical skills to open up the Beogram into service position and change the tacho disc...or even check the Beogram connections. Not removing the top platter would not have damaged the tacho disc. A loose top platter could bounce around and damage the upper deck components though.
The turntable is located in California near Los Angeles, could you recommend someone if you know of someone that deals with Bang and Olufsen. I will have the buyer check as much as he can without taking it apart, maybe it is something at hands reach that can be done. Buyer said the linear arm is still functioning properly. Thank you for your reply's they are helpful to my situation.
I don't know any Beoworld technical people in California but maybe someone else on the forum here does. One thing the buyer can check is with the top platter removed, check that the sub-platter is seated good. With power off check that the platter spins freely in both directions.
sonavor
I will have him check the sub-platter to make sure it is seated properly, also will call around the area he lives in and get a estimate to repair.
