BeoGram 8000 Series
Hi all,
 Is the BeoGram 8000 series Datalink-compatible with the BeoCenter 9000?
 -Tim
Yes!🙂
Thanks, Peter!
-Tim
Hello all
But I think that will only play and stop function well working.
I have Beogram 8002 connected to Beomaster 5000 and when I use return or advice function in the MCP, the Beogram recognize them as stop function.
Tomasz
That could be true! Must confess to only ever using start and stop!
Do the << and >> functions work, or is that what you mean? Should move the arm about 8mm in either direction. If it does not work then its just start and stop. There is a B&O tech tip or like on this which also references the later systems.
beoaus.
