Hi all,
Is the BeoGram 8000 series Datalink-compatible with the BeoCenter 9000?
-Tim
Hi all,
-Tim
Thanks, Peter!
-Tim
Hello all
But I think that will only play and stop function well working.
I have Beogram 8002 connected to Beomaster 5000 and when I use return or advice function in the MCP, the Beogram recognize them as stop function.
Tomasz
Do the << and >> functions work, or is that what you mean? Should move the arm about 8mm in either direction. If it does not work then its just start and stop. There is a B&O tech tip or like on this which also references the later systems.
beoaus.
