Hello everyone. I recently got my Beogram 8000 from being repaired. Unfortunately, it seems to have developed a new issue. The lamp inside the sensing arm no longer illuminates. I'm pretty sure it was still lighting up at the repair shop, so it may have happened on the way home, but I'm not entirely sure. Oddly enough, the tonearm usually still manages to find the edge of 12" records, at the least, though it sometimes misses the presence of the record entirely, progresses to the end stop, and returns to the rest point.
Anyway, how would I get at the lamp to replace it? I recall hearing that on the 4000 series models, the cap on the end of the sensor arm can be removed, but that doesn't seem to be the case on the 8000, at least as far as I've been able to determine. Also, is there a wire to check and see if voltage going to it is present at all? Thanks in advance!
-Adam
