Beogram 8000 dead
Hi Lee,
In times like this you have to get back to basics. Start with the power and work your way to operations.
Open up the Beogram into service position. Check the power from the transformer to the rectifier and verify the DC voltages. You have to make sure nothing funny is going on with the power or else the processor won't function. The transformer assembly has a fuse inside it so it is possible that is blown.
I also have to ask if you checked the solder joints you re-soldered under magnification. Those Beogram PCBs have a lot of small solder pads and it would be very easy to have a short between a couple without realizing it.
Double check your recap work.
It would also be good if you can post several detailed pictures of the boards (component and trace sides).
-sonavor
Reading your original post again, since your Beogram opto assembly light illuminates then the transformer fuse must not be blown. Still, check the power supplies especially the +5 VDC to the processor. It sounds like the processor is not functioning now. If you changed the small electrolytic 47uF capacitor inside the processor housing, did you make sure the ground was connected to that correctly? That capacitor is a little tricky to get installed correctly.
-sonavor
Difficult now. It's always easier to find problems with natural causes than to start with something that was already "got at".
You may have introduced one or more new problems, that, combined with the original fault, could make diagnosing more difficult.
Having said that, you may - or may not - have cured the original problem. Difficult to say.
That's why I usually recommend diagnosing and repairs before doing upgrades, blanket replacings or "once overs".
But check your work.
Check if you accidentally connected two pins by flowing them together.
Did you make sure to solder the ground/negative side of C28 in the metal box with the microcomputer IC properly? That board is a little different as it has some solder pads on the component side.
-sonavor
Looks exploded to me...
And did you introduce the ground connection at C27, - the one that is lost when you take out C27?
