Beogram 8000 - resistor R25
Hi
Upon recaping BG8000 PCB I spoted a broken resistor at R25, it is snap in half.
I presume its better to replace it but I wonder what function does it have.
As a side note the lamp at the tracking sensor is dead and the arm does nt move more than a few cm in the plater without returning to the starting point... is there any connection with this broken resistor ?
Any information its very welcome
Kind regards
Vasco
The resistor works in the circuit providing a slower forward towards the lead-in groove.
Thank you Dillen
Vasco
Search on beolover.com’s blogs for this specific issue. You will find a huge amount of useful information that should help you get a clear answer.
The beolab1700 is type2605 , and the Beocenter 1400 is type2604 , or do you mean the type of transformer?
