Beogram 7000 - Moment -Beolab 28
I have had a B&O installer install Beolab 28’s . They connected my Beosound moment with a wired connection to my 28’s and using line in from my Beogram to the Moment, and line in on my 28’s from the wired speaker connection from the Moment. I was able to listen to my records.
After not using the Beogram for a few months, I put a record on to listen . The set up has stopped working. The moment registers a line in input when I start the Beogram. However when I select line in as the input for my 28’s I get no sound. The 28’s work fine with Deezer, airplay and radio.
I have reset the Moment and tried configuring for wired and wireless speakers, but it doesn’t find the Beolab 28’s . Any suggestions or help would be appreciated.
As an update, I have got it working, having spent hours rebooting, repairing and generally trying all the settings, I got it working. I think it was the multi room setting that made it work. I am now playing the Beogram 7000, line in on the Moment, and Moment in control in the multi room menu. Hopefully this setting is easy to get back to, when I change it.
