Hi all, Small but annoying problem i have is that on the end of the arm where the speed illumination shows either 33 or 45 RPM.
Mostly when i use the machine the 33 RPM light does not come on. But always the 45 RPM illuminates every time when chosen.
Sometimes after using for a time then the 33 RPM will come on...
Can anyone help with this minor but annoying problem
Thanks Sandy.
