Beogram 6500 arm stuck in position
Here I am again!
Earlier this year I bought a full Beosystem 6500 in white.  The Beocord needed new belts which I replaced myself, but the Beomaster had more complex issues, so I have had that repaired by John at Merlin.  I've just got it back and it's fully working (thanks John!).
I had only tested the Beogram turntable briefly before, but now that I have the Beomaster back from repair, I set up the whole system and I think for the first time played a whole album (or side 1, anyway).  It played fine, but then when it finished playing, I heard an unpleasant clicking noise, and when I lifted the lid, the arm was raised but stuck in position above the record - it appears to have tried to return to the right, but had only moved a centimetre or so, and stuck there.
With some difficulty I remove the record and removed the platter and wheel.  When I removed the wheel and belt that sit below the platter, the motor was spinning constantly as though stuck in play mode.  I have disconnected it from the mains, but if I reconnect, that motor starts spinning.
On the inside, I notice that the raise/lower cog is in the wrong place and I cannot turn it manually more than a few mm either way.  The main cogs that drive the arm however are completely stuck - no movement at all.  If you try to move the arm left or right, it is also completely stuck in place.  Obviously, I don't want to force anything for fear of causing damage.  I've managed to fix a Beogram 9500 before (the wire drive had come loose) but I'm stuck here.
I have attached photos of what I see inside, in the hope that one of the experts here might recognise the problem.
That's odd, why is it doing that?
Minor update - I have managed to get the raise/lower cog (part 1636 in the service manual) back to it's correct position.  The start/stop cog (part 1604) is still stuck firstly in position and will not move at all.
I am unable to unscrew and lift the top panel to get a better look inside as the arm is stuck in a position that doesn't give clearance for that.  I suppose I could disconnect the wire drive from the sliding chassis in order to move the arm and then lift the lid, but I'm reluctant to do that, especially since I am really not sure if it will help.
I have looked inside my Beogram 9500 for comparison and the raise/lower cog 1636 is now in the same position as the 9500.  In the 9500 the arm can easily be moved by pushing it, and the start/stop cog 1604 can be moved easily (if reluctantly!), but on the 6500, both of those the arm and the start/stop 1605 cog are stuck very firmly and will not move at all.
Today I plucked up the courage to disconnect the wire drive that moves the tonearm.  With that disconnected the tonearm moves smoothly, but it made no difference to the start/stop cog (part 1604) - still completely stuck in position.  I can see nothing broken so I'm sure it's something out of place in the mechanism, but I'm buggered if I can find it.
This is very hard to triage remotely. Are you saying that if you attempt the “In/Out travel of the pickup arm” instructions that cam wheel Z (1604) does not rotate? Is Swingring Y frozen as well?
I realise it's not easy to triage remotely, so thanks yery much for trying.
Yes, exactly as you have said.  Cam Wheel Z (1604) is frozen in place.  So is Swingring Y.  As a result of those being frozen Wire Pulley A is also frozen, even if I remove the wire.
If I do remove the wire from Wire Pulley A, the tonearm moves smoothly, so the only thing that I can gather so far is that the tonearm is not the cause of the problem.
My approach would be to start disassembling the mechanism to determine when it frees up.
Yes I'm sure you're right.  I don't think I'm confident enough to do that myself.  I'll take another look at it tonight but it seems likely I'll need to get a professional to look at it.
I know Multicare will be able to fix it, but I was just hoping to avoid a long drive to Leeds!
You have pictures so as long as you don’t break tabs you should be fine.
