I have just unpacked my B&O 6500 system and re connected it to the 21st Century. I have a problem with the Beogram 6500 turntable. Unfortunately my Dad didn't fasten the transport screws down when he packed it away for me (I can't give out to him as he did try his best).
Now when I press play on the Beogram the tonearm is not moving to the vinyl, it drops on the base of the unit missing the album. It also won't move when I try to adjust it with the move buttons. If I move the Arm manually and lower the tonearm onto the record it will play for a brief while then lift and shut off.
Can I fix this myself or is this a big problem? I spent the last 20 years fixing slot machines on cruise ships and have a bit of technical ability.
Second part of the question is can anyone suggest a good company in the Republic or the North of Ireland to fix the turntable?
