Beogram 609/42VF pickup
I got a Beogram 609VF which I understand is the same as a 42VF.
The pickup needle was bent in transport, and upon finding a new one I realised that the SP14 pickup that was in it is not the correct type.
As far as I can find out it has to be a SP1 or SP2 instead because of the angle of the pickup arm. These seems to be harder to find, so my question is if there are any alternatives for this Beogram?
Thanks in advance
The SP1&2 used a different stylus replacement form from later modeis. One source is
Thank you very much Mark
A follow up question:
I guess this stylus somehow mounts into an existing cartridge, but does that cartridge have to be a SP1/SP2 cartridge or can the one from a SP14 also be used?
Thanks in advance
I don’t believe so. The stylus on an SP14 includes the outer shell as an integral part of it.
Ok good to know. So I will have to look for at least an original SP1/SP2 cartridge I guess
thanks for the info. Very apriciated
I recently acquired a SP2 pickup but it is not fully working. The cartridge seems to suffer from sort of corrosion, and the sound is only coming out in the the left channel.
I have tried to loosen the screw on the cartridge, but the casing does not seem to move when I try to pull it.
Any tricks on how to disassemble a cartridge like that, and any thought about the missing channel? Could it be a corroded wire inside?
Before trying to remove the stylus, use a meter to measure the resistence between the two channels using the pins. Looking directly at the back of the B&O SP2 cartridge (with the stylus pointing down and away from you), the four pins are arranged in a diamond/square pattern and mapped as follows:
  • Top Pin: Left Channel Hot (L+)
  • Bottom Pin: Left Channel Ground/Return (L–)
  • Right Pin: Right Channel Hot (R+)
  • Left Pin: Right Channel Ground/Return (R–)
They should measure within 10 ohms and be between 600 and 1200.
Hello Mark, and thanks for your answer. I am not sure about the arrangement of the pins that you mention. It is the same Pin placement as an SP14, but the angle on the cartridge and the form of the casing suggest that it should be a SP2 unless I am totally mistaken. Here are some pictures of it:
I have tried to measure resistance between the legs. I measure 1.250 ohms between the 2 legs on the right, and the same between the 2 legs on the left side of the cartridge,
It is not in the range of SP10 - 14 and they had clear stylus guards. It is likely between SP2-9; however, if the screw is original, it is definity on of the SP2 series. Having said that I inadvertantly gave you the pin arangement from the stylus side. Your measurements indicate that both channels' coils as well as their connection t the body are fine which means you'll get sound from both channels. Given that I would be more suspicious of the tonearm wiring or muting switch. If you are using RCA inputs to your preamp/receiver you can simply swap channels to test this. If the dead channel moves its in the T-T or wires/connector; if it doesn't its in your amp.
As to removing the stylus, I would carefuly use a sufficient wide flat-tipped screwdriver to catch it between the body's raised edge and the stylus cover and slight rotate it. Do that in 4 to 6 places around until you can work it free. Good Luck!
Mark-sf wrote:Given that I would be more suspicious of the tonearm wiring or muting switch. If you are using RCA inputs to your preamp/receiver you can simply swap channels to test this. If the dead channel moves its in the T-T or wires/connector; if it doesn't its in your amp.
I have tried to use a SP14 on the deck and get clear sound in both channels with that, so I do not suspect the Beogram itself or the amplifier.
The Beogram has a 5 Pin DIN conenctor, but I might try to make an adapter to swap the channels just to see if I am overlooking something
