Hi all
This is an quiet old discussion but I stumbled today over this.
I had a similar problem with a humming at each relevation of the platter, even with a new lasercutted tachodisc from Dillen.
Today I decided to put a small amount of T 7000 glue underneath the black subplatter ( only at the inner hole and only a small amount) just to fix the subplatter to the spindle.
The glue is usually used for mobilephones to attach the backcover, and you can remove the glue easily with your fingers, peeling it just of.
The humming was gone in seconds.🤩
There must be a tiny gap between the black subplatter and the spindle with the tachodisc. A little rattling which is audible through the pickup system.
In my opinion there is a constant regulation for the speed and this regulation is always working a little (very little) bit because it´s a dynamic process to keep the platter at a constant speed.
For me it was a solution and I´m happy again to listen to my records without a humming between the tracks ;-))
Stay tuned.
Best regards
Christian
