Beogram 6006/8000/8002/TX creaking dustcover hinge
Hello, I'm restoring a Beogram TX, and I'm having an issue with the dustcover hinge - it creaks loudly when lifting/lowering it. I've dismantled the hinge several times, tried adding some lubricant between the plastic guide and the plinth, but it doesn't help. I noticed in an article on Beolover's site, that there should be a teflon strip between the plastic guide and the plinth main body, which presumably allows the guide to slide more smoothly; howeer this is absent on my Beogram. Does anyone know the size of the teflon strip and how it is attached to the plinth - presumably some type of glue? The service manual is of no help here Thanks in advance Pete
Hi Pete, Look at this: https://www.dksoundparts.com/product-category/beogram/beogram-tx/ Regards, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Hi Yann, Yes, I have seen that. However, as far as I can see this does not include the Teflon strip. Regards Pete
The teflon sheet is apprx. 2 x 3 cm. Martin
Thanks, Martin. I've replaced the teflon, and problem is now solved.
