Sometimes (and more often since a few time), the arm of my Beogram 6006 does not return to parking position at the end of the disc.
It happens when the end-groove is very close to the center, so the reading arm is far on the label.
When pressing stop, I hear the motor spinning but the arm does not move. Same with the fast return key.
It looks as the moving cart has gone out of the guiding spindle.
Today, I solved the problem by moving this spindle by hand, but it is not satisfactory.
A played a "shorter"LP with a larger end-groove palyed without problem.
Can I check something?
Thanks by advance,
Yann.
