Beogram 6000 output.
Hi all I have a beogram 6000.
It's one with a built in riaa but it seems the output is low I can nearly max out the volume control.
I am using it with a none bang and Olufsen system. And using it in to a Densen pre amp.
When I have looked up the beogram 6000 it says the output is 200mv is this correct?
Many thanks
Could there be a fault in the cd4 unit the inbuilt phono stage.
Many thanks
