Beogram 6000 mystery spring
Dillen to the rescue on this one i think! 🙂
Failing that - Tim Jarman from BeoCentral is your man, but we have plenty of BeoGram experts on here i'm sure can help. Anyone?!
Lee
Rings no bell here.
Keep it, you may need it someday.
That makes perfect sense! One of the lid screws was missing in my machine (luckily, not the lug - I replaced both screws with regular Phillips head screws, easier to work with since you can't see them). Perhaps the spring is supposed to push the lid holder lug up so the lid is easier to install, or just to keep it from rattling around when they are loose?
Maybe I'll list it on eBay as a genuine vintage B&O spring 😎
I'm continuing an age old topic as I can now confirm what I suspected. I had a 4004 open, and it still had these springs where they are supposed to be - they are indeed under the lugs that keep the lid in place. So when the lid screws are loose, the springs push the lugs up so you don't need two screwdrivers and four hands to conveniently slide the lid under them 🙂
Apparently the springs get lost the first time somebody who doesn't know about their presence completely unscrews the things...
Thanks about that Mika!
I too had these springs gone wild into the deck, now back to where they belong!
Jacques
No truant mystery spring in my most recent BG4000 acquisition. But I found a loose bolt, a needle brush (!) and a coin inside it, all ready to interject themselves where they shouldn't. I'm guessing the coin has been there quite a while, going by its date.
Haven't figured out where that bolt belongs yet.
