Beogram 5500 stylus landing short of the record
A friend of mine recently got a second life Beogram 5500.
One problem is that the stylus is lowered a bit outside of the record.
Is that something that can be easily adjusted?
Happens mostly when the plastic tab on the carriage has broken and replaced by something else. There is a easy way to solve this. Take off the platter and shift the carriage to the middle a bit. You will see a small gear with + AND - AROUND it. This one sets the landing point (for 45 rpm, but also indrectly for the 33 whem the tab has been replaced)
Thanks!
This has been fixed now.
