Beogram 5500: Arm "sliding" across record
I seem to recall others experiencing what I'm about to describe, but I can't find the threads. . . .
When I press Play, the arm sets down correctly, but then begins sliding across the record toward the center spindle. It's as if it doesn't have the correct tracking force, even though it does. Thoughts?
So I did find one other instance of the same issue. Unfortunately, no resolution was ever reached.
/forum/general-discussion-and-questions/beogram-5005-skating-problem
Just a quick question is the plastic guard cap down on the cartridge? If not flicked up fully this can cause it to just skip across a record!
Sitting: BeoVision 11-46 on Motorised Floor Stand - BeoLab 11 Wall Mounted - BeoRemote One - BeoCom 5 with Speaker Base Dining: BeoGram 3000 Type 5228 - BeoSound Core - BeoLab 28 - BeoRemote Halo Kitchen: BeoSound 1 - BeoRemote Halo - BeoCom 6000 Bedroom: BeoSound 35 - BeoRemote One - BeoTime Guest Bed: BeoLit 20 Study: BeoSound Core - BeoLab 8000 - BeoCom 5 on Speaker Base Gym: BeoPlay A9 On The Go: BeoPlay H7 - BeoPlay H5 - BeoPlay E8 3.0 - BeoPlay H95 - BeoPlay EX
Worth asking, because stupid stuff happens, but yes, the stylus guard is up.
Is the MMC ok?
Sometimes the stylus is broken and the needle is bent upwards or even complete missing... then the MMC case slides over the record...
Yep, I just about to post that I looked more closely at my cartridge, and sure enough the stylus has broken off. Oh well.
