Hello everyone,
I was given a Beogram 5005 that seems to work quite well. However one issue I am having is that when the stylus is first placed on the record, the stylus seems to “collapse” or be dragged to the right of the cartridge toward the outside of the record. This causes audible distortion. The tone arm seems to track pretty decently, it’s perhaps a little out of parallel, but I’m not sure what the issue may be. When this happens, I can very gently push the tone arm to the outside of the record, without skipping the groove, and the issue is resolved until the next time the tone arm is raised and lowered. I am aware that tone arm parallelism can be adjusted with screw C. I’ve also read some people who claim that the issue is that the tone arm advance shutter needs to be shifted forward or backward, basically leading or lagging the tone arm advance. If I had to guess, I’d say that it looks like the tone arm wants to rest ahead of the groove, causing the stylus to deform to the right side (from the video perspective). any thoughts would be welcome here!Beogram 5005 needle biasing to outside of record
It really does seem as though even when the stylus is straight before it drops, once it drops, the cartridge pulls to the inside relative to the groove and causes the stylus to bias to the outside.
Good news and bad. good news: Adjusting the pickup parallelism really does seem to correct this problem. bad news: screw D is stripped (standard screws should be outlawed) and that’s the screw to make the adjustment properly. For now. I’ve shimmed something under the plastic pin that goes up against set screw D, to rotate the pickup parallelism a small amount. If I can’t eventually get that screw moving, I will tack glue a tiny piece of plastic thereto effect a reversible but longer term repair.
I sincerely hope none of this is offensive to anyone. I’m ultimately trying to keep the deck in service, nobody around here is going to be paying for a replacement cartridge any time soon, and I’m hoping that nothing I do is going to permanently alter the 5005 in a negative way.cheers and thanks for the input.
