Beogram 5005 an Beosystem 3
Dear people, the Beogram 5005 does not have a built-in amplifier.
Is it possible to connect it directly to the Beosystem 3 or do I still need an amplifier in between?
If so, what would be suitable?
I would like to have it in my setup :-)
thanks in advance for the answers
Hat niemand eine Idee?
ginge auch ein älterer Beomaster 3000?
Sorry to answer in English.
Yes, you need an RIAA box to connect a BG5005 to… Anything that is not a Beomaster or a phono amp.
Which one is up to you: from cheap ones from the Bay to expensive dedicated ones, they are plenty of choices: it all depends of your budget, ears, tastes and needs…
Hope this helps.
Thank you matador :-)
can you recomend a special one?
