Hi all,
I recently acquired a Beogram 5000 Type 5803 in ok visual, condition but not working.
The tone arm doesn't operate properly. Sometimes,
it cues over the record but doesn't drop,
when it does drop, when you stop it, it doesn't lift back up,
the arm never returns to rest, it only just gets of the record and then stops,
sometimes when you go to cue the arm, because it doesn't lift up, it smashes into the side of the record (dont worry, I fitted a stuffed cartridge to it when testing it).
I've pulled it apart and visually I can't see anything obvious, though I know nothing about these machines technically and this is the first Beogram I have pulled apart. Only thing I saw, was a long spring that didn't have any tension on it secured at the base of the tone arm assembly and when the arm moves left and right, the bottom semi circle black plastic of the tone arm assembly rubs on the top of this long spring?
Anything I can check with the arm operation before I throw in the towel and take it to my local B&O repair centre?
Also, the balance weight at the back of the arm moves in and out and also turns left and right. Is it supposed to be able to go in and out?
