Having opened it up and checked it over. I found a bunch of components dislodged and the tone arm drive wire missing. I suspect someone tried opening it with the arm in park, but there don't appear to be any broken parts.
I've fabricated a new arm transport drive wire, and relocated the dislodged parts and springs. The unit powers up and spins the platter briefly, but the unit doesn't respond to the buttons or beolink control.
Turning the pickup arm travel and lift/lower gears, the switches engage and spin the main platter drive motor, the pickup arm transport motor and the lift/lower mechanism.
At certain points, the solenoid plunger will shoot out. Sometimes the transport will bring the arm to the 'single' (45) position and lower the arm. Moving the arm (I don't have a cartridge installed, so I've just added a piece of blu-tack to give it weight to allow it to lower). Gently pushing the arm to the left triggers the transport motor. When the arm reaches the centre of the disk, nothing happens (the platter continues to spin, and the arm stays in the lowered position)
The above proves that the motors and solenoid appear to be functional, and the mechanical components aren't damaged, but it the unit will not respond to the buttons or beolink.
With a mutimeter on pins 5-11 of the main IC, I can see that the buttons are working and drop power from 12v when pressed (press to break switches), so the problem seems to to me to be either with the chip or downstream of its outputs.
Other info - the platter light initially stayed on all the time, but doesn't light up now, and the disk speed indicator LEDs on the arm transport both come on from time to time, but there doesn't seem to be any logic to that.
Reading up on the spec sheets for the main IC, it looks like it's a programmable chip, and the B&O parts list identifies it as a 'customised part', so I'm guessing it was programmed by B&O and isn't a straightforward swap?
I don't have a cartridge, and there's no point getting one yet, if the main IC (and therefore the board) is effectively dead.
Any advice on what steps to try next to diagnose whether the main IC is dead, or if the problem is downstream of it?
