Clutching at straws but the service manual shows P6 as being a '
socket 6-pins' and in the exploded parts diagram PCB1 is shown with just the socket in place (no attached plug or wire showing).
The 'plug' would then be part of the connector from the muting module (module 11).
I think it should come apart. (It's possibly a old Molex right angle PCB connector - something like this:
link )
IMPORTANT EDIT: But the service manual does cover a variety of Beogram models so there may have been variations of connector - like in the BG3000 video that you mentioned. Also, if you look at Condor Audio's BG4500 restoration, the cable appears to be soldered directly to the board, perhaps another variation or a modification (possibly after breaking the previously connector - so be careful!!) Condor Audio BG4500 pdf here (perhaps @yachadm of Condor Audio can comment):
EDIT 2: This advert appears to show your BG4500 board with the connector disconnected:
