Hi - I put this under a separate thread so it would be easier to find if someone else needed to reference this.
So my 4004 is now turning, it has had new trimmer pots on the main board, the relay was causing speed fluctuations and has been by passed pending a new one being installed (as per someone elses suggestion in another thread) However I am still getting speed fluctuations - tapping the fine speed trimmer seems to cause the fluctuation in just the same way as the relay unit did. Searching the forums this part is no longer available and in another thread someone suggested disconnecting it or bypassing it - does anyone know how to do this?
