Geoff
Sorry,didn't take any pics.I'll describe.I can't claim the patent on outfitting LEDs on these machines as I have seen it done on this forum.
-First mark how far the lamp protrudes into the housing.
-Next I cut away the square block portion that is filled with adhesive holding the lamp.
-Then tack the LED in place inside the housing with a drop of hot glue,taking note of polarity,and placement as original.
-Then place masking tape,as a filler to the back section,over the leads.
-With the LED firmly in place,and the back hole sealed,I added a more generous portion of glue to encase the back of the LED and fill the back.
-After the adhesives dries,Peel away the tape.
-A dab of black paint or permanent marker to the back of the adhesive to seal out light and give a finished look.
-cut the Leads to approx .25 inches,solder a light guage wire salvaged from a 1/8 watt resistor to the negative lead for flexiblity when adjusting.
-solder a 1k 1watt resistor to the possitive lead.
-Re install everything and put a bit of a bend in both the thin wire lead and the resistor to give flexibility when adjusting.
The interesting thing about this project was the 1 watt resistor I used.It is physically the size of a 1/8 watt carbon comp.believe it or not.I accidently ordered it for a different project and thought I had either ordered the wrong part,or they had made a mistake.After looking into it,the resister is indeed a 1 watt,designed to be extra small.I was sceptical of it's use in the tube amp it was originally ordered for,but I tried it here.The small size made for a nice clean job,a full size resistor would have been a tight squeeze.I ran it non stop for a few hours last night.It seems to be working well.
If I had to do another,I would probably use epoxy as a filler for a more robust,finished look.
I regret not taking step by step pics!Oh,well..I guess I will have to buy another Beogram. 👍
Regards
Paul
