I was able to find a Beogram 4002 in practically perfect condition at a thrift store and have been doing a restoration on it. I have replaced all the capacitors, the old large carbon resistors, the TIP power transistors, oil infused the bearings in the motor, and torn down and cleaned and lubricated all moving parts. But when I tried to see if it would play a record for the first time, three things did not happen. It started an switched to 33 rpm but does not find a record on the turntable and does not switch to 45 rpm. It just continues towards the center spindle and then returns and shuts off. If you press the 33 rpm button the light turns on, but the 45 button does not turn on the light or activate the motor. I have looked at the speed selector circuit in the manual to see what components might be involved and need replacing. I had replaced both relays as well as the trimmer resistors for 35 and 45 rpm. So I looked at the manual and have now have replaced IC2, TR8 and TR17. I have a transistor tester and they seemed to be alright but I replaced them with new ones anyway.
I also have an extra control panel and keypad I could plug in so I know that the problem isn't there. Because this Beogram was in such great cosmetic shape I had hoped a capacitor replacement and good clean might be all it needed. I can solder and use a multi-meter but that is the extent of my skills. Any suggestions about what else might be checked would be appreciated.
Thanks,
John
