Thanks, guys!
It has been a while since my last update. I got a little sidetracked. I have had my working Beogram 4002 packed away as we got a puppy late last year and needed to pack away the speakers as well they were just calling out to be chewed. Molly (the best and most beautiful dog in the world ;) haha) is now beyond her chewing phase and I pray to the dog gods that she won’t find interest in the Kvadrat cover of my Beosound A9.
Login to view image Login to view image
This got me thinking… I have a beautiful record player that is tucked away around a corner, but should in fact have a place front and centre in our little apartment. As such, I decided to take a break from restoring the trashed 4002 and make a record player cabinet. Some of the requirements were:
- oak timber to match the dog
- big enough to house my small but growing record collection
- room for magazines
- room for my liquor collection and glasses
- hidden cable management
- USB cable accessible internally to have my iPad/MacBook out of sight and charging
- the base needs to be tall enough to allow the robot vacuum/mop to clean underneath
- similar aesthetic to the Beogram
- adjustable shelves
So I went about drawing up a minimalist cabinet and then set out to make it.
The carcass is made from solid oak. The front edge will be 6mm to reference the Beogram frame. The idea is that it would look minimalist and delicate. To achieve this I would have to bevel the inside of the carcass and subsequently the doors as well. As such, the doors would have chamfered edges to fit. Solid timber doors are not very stable as wood moves considerably with humidity. I started the build by resawing solid oak into ~3mm veneers on the bandsaw. These got ‘stitched’ together into a veneer leaf. The substrate of the doors is chipboard to provide dimensional stability. However, as the edges of the doors need to be chamfered, this required ~20mm thick edging. I laminated the borders on then laminated the veneer to the substrate.
Some images: Cutting the thick veneers on the band saw.
Login to view image
A stack of veneers
Login to view image
The veneers get ‘stitched’ into a leaf.
Login to view image
Login to view image
Here you can see the wide edges laminated to the chipboard substrate and the veneer leafs off to the side.
Login to view image
The veneer is then laminated onto the substrate using a vacuum press.
Login to view image
