Beogram 4002 Restoration
Hi all, I have just gotten my hands on a pretty trashed BG 4002 so I am trying my hand at doing a full restoration on it. I received it in a really bad condition - the power cable and phono cable had both been cut and are missing, I have no idea if any of the internal electronic components work, the plinth has had water damage, the aluminium strip on the dust hood is wrecked, the chassis paint job is in total disrepair. So in short, I have a mammoth task ahead of me, but considering it is in such bad shape, I don’t feel bad having a crack at it as if I make a mistake, at least I’m not ruining a fully functional record player. My plan of attack is to start with the cosmetic and physical stuff, which I feel most comfortable with, followed by the electronics and internals (which I have next to no experience with and as such will take a lot of research and help). Feel free to chime in with advice and tips! There is much knowledge and experience here which I am hoping to draw upon. Thanks in advance! Christian
First step was to remove the plinth to make a new one. The original was chipboard with rosewood veneer. I assume it has been exposed to water at some point as the chipboard was swollen, and the metal was rusted in parts.   I decided to remake the plinth in oak to match the furniture at home. I milled a few oversize pieces of oak and let them sit for a few days to relieve any tension in the timber before milling them to their final size. I milled up a few extra pieces in case I made any mistakes and so I can test a few different finishes. Each strip of timber will make one plinth so that the grain will be continuous. I have seen a few restored plinths made with a mitre and splines but I think I prefer the original joinery so decided to go with that instead. I programmed the CNC to do all the joinery. I had to make a vacuum hold-down jig as the parts are so small and difficult to secure when milling. The joinery ended up really well. The small details look great and are a nod to the original. This is what it looked like before gluing. Here is the end result. I have oiled one (the darker looking one). I will spray the other one with lacquer. Afterwards I will decide which one I like the best.   The metal fixtures had some chipped paint and surface rust so I removed the rust, sanded them down and refinished them with flat black paint. They turned out great!
Next step was to disassemble everything from the chassis and the back piece of the dust hood. The current condition is horrible. The previous owner had made an attempt at starting a restoration and it seem he had tried to sand off the paint. It was very interesting disassembling the turntable. I enjoy seeing how things are put together and work. I made sure to label everything and take a million photos of how it goes back together. I removed the old sticker labels so that I can adhere them again after it has been refinished. My plan is to have these pieces sand blasted to remove the old paint before refinishing it myself. I have sent off a few emails to get some quotes on the sand blasting. Has anyone got any experience with restoring the chassis?
That joint for sure looks amazing to start with!
This is beautiful work Christian!
Exception work so far......you should offer to provide those wooden plinths to others, not everyone has access to the equipment required to give such a finish. Well done
Thanks for the kind words! I would be open to making these for sale. I was thinking that I could provide them unassembled (not glued together) as that way they can be shipped efficiently in a poster tube. If shipping them assembled, it would cost a bit more for shipping, packaging and labour. If anyone is interested, I can make them in walnut, oak, ash and can likely source rosewood, teak and other timbers.
Would be wonderful if you can make them available! Your joint work is much better than B&O 4000c recreation wood trim joint. I've seen many 400x with banged up corners. This would be a great fix/upgrade!
I haven't seen one in the flesh. Here's a video of the restoration program: https://www.youtube.com/watch?v=c9f6hXYk8ac&t=71s You can email the company featured.
