I'm trying to finish restoring a Beogram 4002 model 5503. The AC motor seemed a bit erratic so I put an oscilloscope on it and I was not getting the expected clean sine wave. Instead, it was a bit choppy.
Following signals around I found out that my DC power had a pretty big ripple in it. I grounded the negative side of the power supply capacitor(s) to the motor housing and all the issues disappeared. So it seems that there was not a good clean ground made through the wires that go from the power capacitors to the motor..
I kind of feel like it is cheating to put in a separate ground wire to the chassis, but things to run correctly if I do that and I get perfect sine waves for 33 and 45. So it looks like an internal motor problem.
Anyone seen this? Should I just go with the kludge?
