Hi all,
After many trials and tribulations, I have completed a total overhaul of my BG6000 Quad, which I bought last year on Ebay from a used HiFi dealer in Toronto. Previously, I thought I that had fixed all the problems, but as I progressed, hidden defects came to light, which the previous owner/technician had intentionally hidden quite skilfully.
This obviously highlights the well-known adage - "buyer beware".
To spare the rest of you BeoFans who own (or are considering owning) this magnificent turntable, most of the troubleshooting I had to go through, I have compiled this list of what mostly needs to be repaired on a unit with an unknown history.
Beogram 6000 / 4002 ToneArm not lowering - Lubrication Points
Beogram 6000 / 4002 33/45 Speed Problem
Beogram 6000 / 4002 CD4 PCB Capacitor replacement
Beogram 6000 / 4002 prematurely ends play
Beogram 6000 / 4002 33/45 LED Indicator Upgrade
I hope you all enjoy this, and save yourselves lots of time, which can be better spent listening to your LP's!!!
Now available in downloadable PDF format:
Menahem
