Hi, advice needed. I'm trying to rebuild a Beogram 4002. The small pulley wheel on the end of the brass lead screw has a split centre, so cannot be secured properly. Has anyone repaired the fixing or know of a modern replacement? Thanks
Beogram 4002 (5524)
Well done! The problem with these is that there a number of different sizes - the hole in the middle can be different sizes! I was sent one by a friend that didn't fit - I repaired my original instead.
It should be lego 😁
