I now mostly have my bg4002 working- except the arm doesnt lift at end of record and then return as should -- i just stays next to the label.
I have the suggestion of condor audio re placing an extra wide black band at the plastic ruler thngo - but that doesnt work for me .
I have noted that what i believe to be the end switch is not activated by the carriage as it stops short by several mm - should it be activated at end of record ?
are there any suggestions to fix the problem?
thanks in advance
George
