Hello,
Yesterday i picked up my first Beogram 4000 and carefully took it home at about 10 miles an hour all the way.
Disaster struck when i got home i noticed the stylus guard had fallen off and due to it just being glued on i thought i could remove the stylus and glue it back on myself.
This is when real disaster struck. As i pried off the stylus, the plastic arm that holds the sylus in place snapped. Fortunately i noticed this before pulling out all the wiring but it is broken.
i edged it back on to see if i had done any damage to the wiring and when it played back it was only playing through one channel. Is this a stylus issue? or maybe it has something to do with the rather poorly wired rca plugs that have been fitted?
So, firstly i need to ask if you know how to either replace the stylus holder or what glue is best to try and get it back to normal. I would prefer that if i glue it, that it can be as strong as originally.
I also noticed that the front of the lid seems to sit on the front of the auminium and not the wood. Around 5mm further back than i would expect. Although it seems to fit flush at the back, leading me to think i cant get any adjustment out of it.
Is this normal?
I can attch pics of any of these issues if needed.
Thanks in advance for any advice
Tom
