Beogram 4000 Speed Issue
I have a Beogram 4000, it works fine at 33rpm but when its switches to 45rpm, its all over the place i.e. the motor slows down, stops, restarts.
Does have any thoughts on what the fault could be and how to rectify it
Thank you for your assistance.
Kind regards
Mark
I would start with the relay that switches between the two speeds....the contacts suffer over time with age, replacements are readily available but will require soldering......it may not be your issue but given the age of these units I would change it out just to eliminate it.....
That's great, thanks. I've seen the video so can see what I'm looking for.
