Hi all,
I am new to this forum, and my two questions here are concerning my Beogram 4000, which is in a very good condition, exept for the tone arm that needs to be replaced by a new (old) one.
The type of arm is the ”difficult one” with five extremely thin leads coming out of the posterior part of the arm. The leads are meant to continue in several zig-zags down through the very narrow system of passages in the arm slide to finally come out underneath it all - to be soldered on to a small circuit there.
Q1: Does anyone know if it is possible to grip all five leads as a group - with a piece of for instance thin copper wire, inserted from behind through the narrow passages, and thus draw the thin tonearm leads downwards through the slides tubular system to be soldered there?
Q2: To be able to measure my tonearm's wireing and identify them, the leads will have to somehow be unblocked and behave like the pickup just has been lowered on to a record - and so is initiating opening for communication.
How do I do that?
I guess desoldering the thin wires from the small circuit board at the bottom while measuring, will solve this problem, but:
Is there a better way?
As I have never performed this kind of operation before, any advice will be very much appreciated!
Thanks!
Best Regards.
Rem: As of now I have disassembled the tonearm slide and separated it, positioning it upside-down ready for soldering. But I have not taken the whole slide-package apart - I hope I don't have to.
Rem2: I do have both the User's Manual and the Service Manual. But unfortunately that doesn't solve the problems. At least not for an amateur like myself.
