Beogram 4000 Noise. Any ideas?
Hi All,
My Beogram 4000 has been making a nasty noise while the arm travels to the record and back.
I have attached a video for anyone that might have a clue what i can do.
Remember to have your sound turned on.
I tried to imbed it but it doesnt seem to be working so just copy the link.
http://s1042.photobucket.com/albums/b424/ifoldaway/?action=view&current=Beogram4000noise.mp4
Thanks in advance
Tom
[Video]
I am afraid that sounds like a very poorly servo motor. This should be whisper quiet. You can try stripping it down and re-oiling (with very light machine oil such as singer for sewing machines NOTHING else!) but from what I have seen in the past once it gets to this stage there is very little that can be done, as the sintered bearings are probably ruined. If you do pull apart check the brushes as these are sometimes near the end of life and if so can cause a short which has other (not too serious) consquences.
I can give tips on how to put the back back on the motor without knackering the brushes should you require!
I would also check the main bearing and main motor at the same time make sure they won't get (if not headed that way already) in a similar state. With the main bearing on a 4000 I take the belt off run the platter up to 33 1/3 using a strobe disk then time how long it takes to stop. Typically you should see > 2 minutes. Again clean old oil away as it could be anything in there and re-oil with singer the main bearings and check the thrust plate is ok at the bottom and not pierced or badly indented.
Regarding the servo the man to contact is Martin (member Dillen) who may be able to supply you with a suitable replacement or give you further advice. I am currently talking to a rep at the original manufacturer and meant to talk to Martin about this (it only started out as a small enquiry after coming across a few examples like yours!) as I have a feeling more and more of these motors will be failing either due to knackered brushes or failed bearings or both! It seems there is a very similar unit but I suspect it will be very expensive, in the order of about £80!
Cheers for the swift advice.
The sound doesn come andd go a bit , so i would hope i can try and fix it before looking for a replacement.
I have the service manual but having never taken the turntable to pieces before, would you say its an easy job?
How difficult is it to remove the motor and place back in?
If its something that should in no way be touche then any ideas who i could take it to?
Tom
Tom the motor is actually easy to access. The whole wooden trim moves forward, thus releasing the upper panels. The correct way of acheiving this is as follows...
Firstly sometimes it is easier to slightly move or remove the dustcover as I have known it to press hard against the panels making them harder to remove. his is easily ahieved by allowing the rear of the turntable to overhang a table edge revealing the two large flat blade bolt heads (recessed under the deck either side near back edge). I then open the lid, slightly loosen the bolts then slide the entire assembly off the back fo the deck.
WIth this being your first time I would also move the tonearm in toward the centre using the controls then unplug the deck - as it is the right rear panel you are interested in at the moment this will give you some more space to work with and allow easy removal of panel and motor. It should be mentioned however it will make it harder for you to remove the main panel and platter. But why not take one step at a time hey? This will reduce any likelyhood of mistakes and the temptation to touch other parts will be removed :)
At the very least put protection over the stylus better still very carefully remove from the arm. Make sure you pull in the angled direction in a downward manner dead straight - I prefer to wiggle in small movements side to side - this will minimise the chance of snapping the delicate cartridge mount.
Now, the proper way of pulling the plinth forward is by using a flat blade object to release some tiny clips that are located between the wooden plinth rear and the chassis on either side at the rear of the machine, the whole wooden plinth (all three sides together) can then be pulled forward. Often you don't have to bother with the tiny clips as people just tend to perform the usual of pulling the wooden trim forwared without thought to the clips and this weakens them sufficiently for them not to work anymore. Once the wooden plinth is fully forward you might notice the panels jump a little.
You can then remove the right rear panel by lifting its right edge up slightly (about 1cm) and sliding to the right. You will then be able to see the servo motor in a black(or less commonly white) casing. You will need to unsolder two wires (noting which way round they are - if you have moved the whole assembly enough to the left these should be easy to access) and then remove the servo belt. Now you can remove the motor with the four screws, the casing splits in two halves and the motor drops out. Dead easy for the experienced it is literately five minutes but please don't rush and take your time.
Lest us know when you get to this stage.
BTW talk to Martin Olsen (Dillen) if you haven't done so already he cannot uforntunately access these forums atm which in my opinion is not good enough for such an important contributor - but I guess that is for another thread!
Let us know how you get on.!
Sounds like an ideal christmas project!
I will give this a go, any advice once i have removed the motor?
Should i completely strip the motor or just apply oil in key places.
Is wd40 any good or should it be specialist fine oil? Just saying as i have some here with me.
If its a strip down, is there any detailed instructions or a video anywhere to act as a guide?
Thanks for all your advice so far Oli, you really are a star an i cant wait to have my BG4000 working smoothly again.
Tom
WD40? Absolutely forbidden! 😡
This is just good for unlocking rusted bolts!
You may use sewing machine oil or even Mobil One!
Olly has an early Beogram 4000 and on later models the bearing is not as good, so I'd say one minute tops.
About the carriage motor, the one on the final 4000s is the same as on the 4002 and it is much noisier. Yours is exageratly so though, and inspection is required. On my 4002 it kept frying transistors because it was dirty. It is however à quality Swiss, long life motor so à good cleanup might be enough... Its bearings had no play on mine.
There is a small access cap on the red side for such maintenance, but you MUST be extremely handy!
The word WD40 should be treated as a swear word round here! Best leave that for loosening nuts I wouldn't even use on hinges or my bicycle lol! it is not a lubricating oil it is a Water Dispersent hence the letters WD!
Anyway, the stuff you want is Singer oil, either at a local sewing shop or on ebay? If not singer make sure it is a light machine oil. Any thicker will risk cloggin the pores of the bearing. You should really extract the old stuff by heating and then soak the new stuff in using a similar method but this is a little impracticle, if not impossible unless the bearing itself can be isolated.
regarding the stripping of the motor IMO yes it is nescesary I usually pull it apart clean the shaft and soak the bearings for some time. The back end comes off easily if you carefully pry off with a razor and there is a small circlip at the pulley end of the motor this holds the rotor in place. Remove carefully without distorting (you will have to replace if you bend it) and watch for the washers and the order in which they are removed. The lot should slide out the back end now.
Great deal of care must be taken as these are ironless core motors and can be damaged if you handle roughly.
Getting back together is fidely with the brushes but you can roll a piece of paper in such a manner as to assist in returning things to normal. I could provide a picture if required.
All the above is often enough to quieten a motor down but I suspect your example might be beyond this stage now. Worth trying though!
Hi Jacques have you seen plastic motors on the 4000? I ask because I know the metal motors appeared in early(?) 400x decks usually with an ac motor... Nothing surprises me with these decks though lol!
Regarding the access cap at the rear I think that was originally designed for assembly purposes - There is no access to the rear bearing here and putting oil in this end only risks flooding the small gaps between stator and rotor windings - this ironically might help with a noisey motor but I think a recent example I had with peeling tape on the rotor windings might have just been such an example of oil getting where it shoudn't!
Yes I have a 4002 motor on my 4000. The hole was useful to me, it was possible to see the problem and take/maintain the brushes away!
Ok, i will leave the WD40 where it is and get some sewing machine oil.
Thanks for all your advice. I will give it a go as i am fairly handy.
Any pics showing the internals or a video would be very handy though
Tom
