I recently purchased a BeoGram 4000 from an ebay seller here in Australia.
I would describe it as being in quite poor overall condition but I am nonetheless hoping to resuscitate it. They are quite rare here and I may not see another one for quite a while.
The good news is that I only paid $113 AUD (our dollar is a little better than parity with USD). For that price, I received the BG 4000 and a MMC 20 CL cartridge that appears to be in good condition. In addition the motor is working well and silent, the bearing appears to be in good condition, the bulb in the detector arm works and even the strobe light works. The light in the control panel is out however.
The immediate problems:
1. The worm screw pulley that drives the arm is missing the screw that obviously locks it to the shaft. The result is that the pulley wobbles around on the arm and eventually jams. Does anyone know where I can get a replacement? (I have looked in the bottom of the deck but cannot locate it.) Funnily enough the metal washer and plastic washer are still with the pulley.)
2. When I turn the deck on it starts the platter spinning and I cannot turn it off using the control panel. The leaf springs are quite flat so adjusting these might improve this if the micro switches work. Any advice would be appreciated.
3. Can anyone confirm that the control panels just sit loose? Mine are just flopping around and lift straight off. The leaf springs that actuate the micro switches are quite flat though.
4. Can I fit a BeoGram 4002 wooden plinth to a BeoGram 4000? The one the came with the BG 4000 is badly chipped and I have a nice one on a BG 4002.
5. What can I do about the flaking black paint on the metalwork? This appears to be quite a common problem with BeoGrams of this age in Australia at least.
Here is a photo of the whole calamity, courtesy of the ebay seller:
