Peter wrote:
All good turntables - but so is the RX! There is quite a bit more to go wrong in a tangential deck and listen blind and you will be hard pressed to tell them apart! However we buy often with our eyes and heart rather than ears so if you have set your heart on a tangential, get one. Which one?
I like the 4000 - despite being the oldest, it is by far the best engineered. Problematic to fix but once working, it is a joy. It is all metal and wood so will last for ever - however the aluminium chassis does not like damp and the metal corrodes - I have had one that has suffered from bad starage (not me!)
The 4002/4 is a slightly simpler version - sounds just the same despite being lighter - not quite as pretty in my view and the keypad gets wear marks eventually.
The 8000/2 has the big disadvantage of having a lot of cheap plastics - the hinge explodes and is not fixable except by replacement - and the replacement will eventually do the same. Never found the ribs made much difference - they do sound better with a rubber mat but that rather negates the reason for getting one in the first place. Very clever motor but at the end of the day, they all make the record go round accurately enough for me and I don't measure and can't hear minute differences.
Cartridges do however make a difference. I loved the MMC6000 in my youth - my favourite of all B&O cartridges. However I doubt there are many left in any sort of decent condition. The 20CL is a good substitute as is a Shibata tipped cartridge from Axel. The S has sibilance in spades in my experience and is the wrong colour!!
The TX or 6002 is a forgotten deck - in many ways a 4002 with the new styling and cheap plastics. I would personally get the 4002 but the 6002 is usually a real bargain.
Hi Peter,
I am certain that you know how much I agree with your views on the Beogram 4000.
The esthetics aside (the 4000 is simply gorgeous!) there is a bit more to the difference between the 4000 and the 4002.
I especially like the single button for forward/fast forward and return/fast return. The 4002 has 2 separate buttons which are not nearly as refined or as easy to use. Nice touch having a single button where increased pressure gives you increased seep. Very nice touch!
Then there is the strobe. True you don’t need it much, but it is nice to have and is visually interesting.
I rather wish that my 4000 was a better example, but it didn’t have an easy life, repaired by a shop that didn’t understand it, and then shattered in shipment to me.
However in spite of it’s inauspicious past, this Beogram 4000 still manages to delight and remains my best performing turntable out of six.
One last thing, the buttons on the BG 4002/4004 do indeed suffer more than the 4000 for whatever reason, but I found using a cloth instead of your finger prevents this issue. Perhaps a bit OCD, but it works.
Jeff
