This is my first post and I’d like to apologize upfront for asking a question that I think is similar to ones that have come up before. Nonetheless, after researching through various postings in both the current and archived forum, I’ve not found an exact answer and so thought to ask it here – would anyone be willing to give me your thoughts on the pros and cons of the Beogram 4002, 8000 and 8002 in comparison to one another?
As background, I’m looking to replace (well, maybe “add another turntable in addition to” might be a more honest phrasing) a Beogram RX that’s given me problem free service for 30 years and would like to obtain something that would be a meaningful upgrade. The RX has been a wonderful, basic deck that got a new lease on life recently by virtue of a Sound Smith SMMC 2 pickup but I’ve never lost the desire for one of the top-line B&O turntables that, frankly, were beyond my means all those years ago. After recently deciding it was time for a mid-life crisis and figuring that the more usual choices of sports car or mistress would be too dangerous or too expensive, respectively (or maybe it’s the other way around?), I’ve instead settled on trying to build that stereo system I always dreamed of in my youth. That choice, incidentally, also seemed to go over better with the wife. In any event, I’ve found professionally restored versions for sale of the aforementioned models but am having trouble deciding between them. My objective is improved sound quality compared to the RX, along with reasonable assurance of reliability for years to come if treated kindly, while retaining the clean elegance and ease of use that all three of these models have in abundance. The turntable will connect to a Parasound P7 preamplifier having an internal, RIAA-compliant, phono module, rather than go through a B&O system in case equipment compatibility is a consideration factor. I understand that the RX was specifically built for compatibility with non-B&O systems, and it mates well with the Parasound, but believe the 4002, 8000 or 8002 should be fine too if used with an appropriate DIN-to-RCA adapter cable?
In researching through these forums and elsewhere, I’ve come up with the following short list of pros and cons for each model in relation to the others. If any of the following is wrong or if there are other relevant considerations, please let me know. It was sometimes hard to tell with a few of the following points if the comments were borne out by firsthand experience (e.g. platter rib concern).
Beogram 4002
Pros: Much sturdier construction and easier to service/repair yourself. Better torque. MMC20-series pickups may be more robust than the later MMC1-5 design.
Cons: Older and therefore possibly having a more limited remaining life-span (hopefully mitigated by the restoration work). May be somewhat noisier in operation. Belts will require periodic replacement. SMMC20-series replacement pickups, if needed, are a bit more expensive than the SMMC 1-4 line and don’t match the tone arm as well as the MMC20EN or MMC20CL pickups. Platter ribs not as supportive as the 8002 platter and may cause surface dampening problems (at least according to a Hi-Fi World article). Performance specifications lower rated than the 8000-series (at least on paper).
Beogram 8000
Pros: Tangential drive design eliminates need to replace belts and results in fewer moving parts to break. Better specs compared to Beogram 4002 (not sure if that translates to real-world sound performance differences). Quieter operation.
Cons: Plastic Tacho disc degrades over time (mitigated by replacement with metal disc as part of restoration process). Lower platter torque than 4002. Poorer build quality. Dust cover hinge design bad and prone to breaking. MMC20-series pickups limitations as described above. Similar platter rib issue as 4002 (according to Hi-Fi World article). Microprocessor out of production and failure will deadline the entire unit.
Beogram 8002
Pros: Same as 8000 plus metal tacho disc and anti-static platter. MMC1-5 series pickups are newer and may therefore have longer life remaining. SMMC 1-4 replacement options are a better aesthetic match to the original pickups. Newer and so parts may have more life remaining compared to Beogram 8000.
Cons: Same as 8000, minus tacho disc and platter rib concerns. MMC1-5 series pickups may be less robust than MMC20-series.
Again, appreciate any corrections, additions or comments to the above. Sorry for the very lengthy post but thanks in advance for any feedback. Also happy to provide additional information if I left out anything useful and the above didn’t already put you to sleep!
