hi again
Sounds like you have a lot more wrong with your BG 4000, the strange thing was mine was working away great but without and incident it just stopped lowering. I've taken the switches board out to finely sand between the points and put back together as believer had done, but no change in the current state of non play. Because mine is working well in all other areas surely it can't be much, it just seems like power is not activating to solenoid.
i would take the switches apart again if i thought it might be that, but I'm not sure after taking it apart already.
Literally everything else works except the solenoid activation, if this worked I'm sure the deck would be fine.
i have another pretty beaten up BG4000 and swap the solenoid from that around but still no change, so i ruled out solenoid being broken and my mate checked it and it seemed fine.
Thanks again
kevin
