I have recently bought this unit. wow what an amazing piece of kit, I love it. The clarity is insane.
Now.....There was a couple of issues, most of which I have been able to fix and get it playing through my hifi. The speed for 33rpm has been a continuing issue. I bought a couple of new belts, this has helped slightly but still the speed is fluctuating a lot. I have downloaded the service manual and this has helped with locating the 33rpm speed on the circuit board and also the motor voltage. I'm still having difficulty. Following the service manual section "speed adjustment", I have set the mid scale on 4VR1 and then adjusted 1VR1 to get the stobescope to best stand still then when all seem fine for no reason it will totally change speed slow or fast. I tried toying with the voltage and this did kind of help but not really something I wanted to play with too much. I adjusted the tilt on the belt motor to the best position to ensure the belt isn't rubbing on anything. Bought some sewing machine oil and lubricated the recommended parts. I'm stuck as what to do about 33rpm as 45 rpm seems solid. There is a Bang & Olufsen in my town, I will contact them but I thought I might put it out there with you all and see if someone may have en-counted a similar issue over the past 40 years ;)
cheers
