Beogram 4000 - adjustment problems
Hello there,
I have a Beogram 4000! It has been repared but there is a little problem of adjustment with the 7". I cannot hear them until the end of the song. Does anyone can help me? I know, it is a prehistoric old vinyl player, but it goes very well with the 12" and I like it very much. Thank you
Have you downloaded the service manual? It is one of the really good and useful ones! Most are designed only for engineers but the 4000 is actually reasonably clear!
I would check for an obstruction interfering with the signal contacts at the left side of the solenoid.
Menahem
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
Have just thought of an easy fix! Sometimes you have the wrong drive belt for the arm - there are two types and one is tighter and a different section. The turntable still works but will lift off the record early. Martin (Dillen on site) can usually help.
Thank you
